DIY Steel mill
Results 1 to 3 of 3
Thread: DIY Steel mill
    Oct 2017
    Netherlands
    Default DIY Steel mill
    Hi!
    i didn't really know where to post this but i have started plans for building my own cnc machine.
    i would like to make it able to cut steel, but it doesn't have to be large.
    the frame i designed is about 600mm x 500mm x 300mm. Now my question would be, what type of spindle would be best? does it need a high RPM or is a low one better?
    And i thought about using a 10mm leadscrew, combined with linear rails. would this be able to take all of the force?
    Thanks!
    Anton.
    Jun 2010
    Default Re: DIY Steel mill
    For steel you will need 'low' RPM. A 24krpm spindle would be useless. I cut steel at 2,000 rpm with carbide cutters.
    A 10 mm leadscrew is possible, but a 5 mm pitch is probably better for that area.
    Linear rails - no problem at all.
    Cheers
    Roger
    Member handlewanker's Avatar
    Sep 2006
    Hi, as it's still in the design stage a sketch of the proposed layout would speak volumes.
    i assume that the size you posted refers to a CNC router layout.......the title of the thread states it's a mill.....two totally different design concepts.
    For steel you can forget making a CNC router........that's mill territory.
    Do you know the difference between a mill and a router.......and the difference between a moving gantry or moving table router?
    Ian.
DIY Steel mill
DIY Steel mill
