Do you the part number to the main control board in your machine?
So I bought a used laser and it currently has laser cut 5.1 installed with it, is it possible to switch it to RD works? I would like RD works because that is what I have currently on my other lasers so it would be less of a learning curve with it.
- Software for 1.6 mW Laser Engrave Machine Software for filled logos ?
- Looks like the Camera idea on lasers is changing the laser world like Glowforge, Muse
- Help or suggestions with Changing controller on chinese laser cutter/engraver
- Changing from 60watt to 80 watt laser tube
- Need Help!- Changing software to Lasercut in FSL
KL-4530 CNC, KL-6060, 5 3D printers, CNC Fusion Converted LMS Milling Machine, 60w Laser Cutter
