- Machining M50 hss component
Hello,
We have a customer machining a small component from M50 HSS (around 30 HRc). ID is 5mm (x16 deep) so will rough drill and ream. Does anyone have experience of machining this with recommended speed and feed rates, when using solid carbide tools with through coolant?
Thanks,
- You may not post replies
- You may not edit your posts
Forum Rules
