- confused with my set up
hello
I am a bit confused with my cnc router . I works ok but the problem is that it seem to be opposite to my mach3 screen.
when the cross on the screen is at the bottom left hand corner my machine is at the to right corner and when i try to cut what on the screen it goes the wrong way.
I have tried revering the motor in the home and limit page but it still goes all wrong. I am not sure if i doing something wrong or what I hope some can help
Peter
Re: confused with my set up
Hi, 2 things you have to do at the very start.......firstly, home the machine for X and Y zero at the bottom left side of the table......secondly, establish your G54 work offset for the start of the job.
If you don't know how to do either of these you need some very basic help and that can be had on UTUBE.
Ian.
- You may not post replies
- You may not edit your posts
Forum Rules
