- G Code Problem
G Code Problem
I have a rectangular shape job with 4.5" x 1.3" dimension. And need to face it down with 0.25".
Face mill diameter is 50mm. (1.968")
RPM = 1000
Feed = 20ipm
Tool No. = 15
Work Offset = 54
Z feed = 0.06"
No of passes = 1 pass
Following is the program I made. But when it loaded to the machine (HAAS VF2) it shows a code error alarm.
T15 M06
G00 G90 G54 X-1.02 Y0.
S1000 M03
G43 H15 Z1. M08
G01 Z-0.25 0.06
G01 X6.54 F20.
G00 Z1. M09
G28 G91 Z0 M05
M30
Red colour line indicates as the line with problem. Pls help me to solwe this.
Re: G Code Problem
I think it should read like this
T15 M06
S1000 M03
G43 H15 Z1. M08
G01 Z-0.25 F0.06
G01 X6.54 F20.
G00 Z1. M09
G28 G91 Z0 M05
M30
Re: G Code Problem
Actually 0.06" is the Z depth for a pass.
Re: G Code Problem
Ahhh In that case, unless Hass G code is different than any other I have seen then
T15 M06
S1000 M03
G43 H15 Z1. M08
G00 Z0.01
G01 Z-0.06
G01 X6.54 F20.
G00 Z0.01
G00 X-1.02
G00 Z-0.05
G01 Z-0.12
G01 X6.54
G00 Z1. M09
G28 G91 Z0 M05
M30
Re: G Code Problem
- G Code Problem
- You may not post replies
- You may not edit your posts
Forum Rules
