Mactec54
Janinio1964
I just found the Nc Studio 8 manual, just follow the correct install from what you down loaded, the V / 8 is different from the older version on how it needs to be installed, you can do this one with the controller card installed, but needs to update before the install starts
Just follow there step by step instructions, and you should be ok
Mactec54
posting 2 pics first is top of code, second it end its just a simple square/rectangle. We were advised to remove M17 and have done that but now it is repeating after zero but moving over a few mm each time.
Hi Mactec54,
You can do a test with V Carve using their own designs, you upload one of those then run, it will do it, and we did do that but still same issue.
I have uploaded photos of the Code, first one is the top and second is the last couple of lines, we removed M17 as someone advised us to and try but it is still looping, goes to zero then starts again but this time moves over a few mm to a different start position. Then continued to do the same moving over slightly each time.
thank you for responding.
Janine
Hi Mactec54
We have installed without card then it said put card in so we did and installed fine.
Have now uninstalled and reinstalled with card in and same issue.
What needs to update before you install? How would you do that before installing?
They did send some images on the flashdrive they provided but no instructions in English as to what they mean or to do.
On the last 2 previous installs of NC5 we just did install, then put PCI card in, then finish and they fired up fine, and I think they are probably dodgy ones!
Janine
Hi Mactec54
We have edited the profile and removed M17 and M30 and it has stopped the problem!
Only thing now is that it isn't going back to zero but we can live with that, do you know of a way to remove M17 & M30 permanently? someone suggested this was possible.
Janine
Put the M30 back in. That rewinds the program only. It doesn't restart it. I think M17 may be the repeat command in the controller that you are using. Just a guess. It can mean different things on different controllers.
Lee
The program is quite messed up, and who ever looked at it for you should of corrected it
G71 is a rough turning cycle, should not be in a milling / router program
M17 Return from subprograms and subroutines can be done with either M17 or M99. As I said there could of been a sub program within your program, there was no Sub that I could see but the use of M17 could of caused the looping
N20 G91 G28 X0.0 Y0.0 Z20.00 this is a bad line of code and if you see this it needs to be corrected, never do a Z move with an X and Y move this can cause a CRASH and ruin your day, it also should of been followed by a G90 to cancel the G91
Never use a G91 unless it is necessary, for an incremental move
Always move the Z first so it is clear of your work then move the X and Y
N02 G0Z20.00
N03 G0X0.0Y0.0
I know you did not write the program, that it was generated from a V carve post processor, it is there software that needs to be corrected, ( Post Processor ) so you can get the program you need for your machine
Mactec54
Hi Mactec54
Can it be rewritten?
I haven't got a clue! It's obviously a dodgy copy as it was written by "mark" so I doubt very much there are very many Chinese men called mark!
I could go to one of our other cnc's and get the PP out of the NC Studio in there but that is an older version and I don't want to mess it up completely!
When we removed M17 it carried out zeroing then restarting but moved over slightly to the right so a new start point each time.
Some monkey obviously wrote this garbage!
Janine
There may be more than ( 1 ) M17 in the Program they would all have to be removed, also the G71's, it will also run cut in incremental, that's ok if that is how the part was programed, look for a choice before you use the PP and switch it to Absolute
Can it be rewritten, Yes it can V Carve have a selection of Post processors for you to try, this is the part that make the G Code Program for you, contact Vectric, the main office and Mark are in the UK, if you are going to buy there software I'm sure he can correct the PP for you
You want to program in Absolute which is G90
Mactec54
what i don't understand is that this is the same V Carve as we use on the other two cnc's we have so why would it be so wrong?
I have just had a look at the PP on there and it is nothing like the PP on the new machine yet it is the same PP
The PP has nothing to do with the NC studio control
The PP is only what the Cad / Cam software use's, in your case it was V-Carve, You have a choice as to what PP you use, check to see if the V-Carve that you down loaded has the same PP option, that you are using to generate the Programs for the other machines
You can use the programs from the other machines, they will run on this newer control
Mactec54
Ok they are all using the same PP i have checked. I have compared and we are using same v carve on all. Just a newer version of NC thats the only difference.
We have done a few simulations and all seems good after removal of M17 and M30.
Tomorrow will do some testing proper.
Wish us luck!
