New build
Results 1 to 2 of 2
Thread: New build
    Sep 2017
    United Kingdom
    Default New build
    Hi I new to this site, planning to start on building my own cnc. Would appreciate any advice or suggestions. 1200mm / 800mm frame size is ideally the size I'm looking at driven by 2 ballscrews on the X and 1 on both the Y and Z axis. What diameter ballscrews would be best choice to drive each axis? Think about using 20mm hwin linear rails, 2 per ballscrew. Would greatly appreciate some feedback from the knowledgeable members. Thanks
    Member awerby's Avatar
    Apr 2004
    Default Re: New build
    I'd say use 20mm ball screws for the X axis; you could go a little thinner for Y and thinner yet for Z. The 20mm rails will work fine; so would 15mm. Have you built the frame yet?
New build
New build
