Depends on the type of table,and how much vacuum you have.
If you are pulling through an MDF spoilboard, than you can cut all the way through.
Need some feedback on vacuum tables.
Do vacuum tables only work if you are not cutting through the workpiece thus with a thru hole the vacuum would draw too much air through the hold and the part would become loose, correct?
So I you want to make something with eventually through holes you need to not cut them all the way through but leave 0.015" or so depending on the material so you don't looks vacuum?
Need some discussion on vacuum tables and details and tips on using them.
HH
UCCNC 2017 Screenset
