Can you help us with this Q series Fanuc? The machine will work on a G0 rapid or in dry run but freezes when it hits a G01 command. All the forums on Goggle speak of the wire break switches which are functioning but may not be sending a command or vive versa.
The other 3 functions Tension, Wire feed and Power on are all working.
We are not sure wear the wire break switch in the cabinet ties into the unit out side the machine.
(Hayden's Supply - Repair has closed its doors due to the unfortunate death of Peggy.)
Thanks,
Mike-FDM of Clearwater
