- Asia need guidance on my design
hi i am making my own cnc and very exited. doing a lot of research on internet for every thing, some questions i cannot find answers . anyhow i have made up my mind on a few things and need to select remaining
1- will use steel rails and home made guidance system using roller skate bearings. dont want to use high end parts on first attempt
2- 800mm x 800mm working area.. i will buy 900mm lead screw (8mm dia 2mm pitch) with brass nut. i think it will give 800mm displacemnt on x and y axis
3- for z axis i will buy whole guidance system. its better this way. it will be 110 to 150 mm stroke, using 8mm lead screw 2mm pitch and brass nut
4- buying 3 axis cnc kit nema 23 motors 3A 270 oz-in steper motors. Driver boards will be 3.5A.
5- 500W or 600W DC spindle motor, 12000rpm max
6- it will be used for mostly wood working, hard or soft wood, plywood plastic etc.. if possible metal engraving too
Based on this information can you suggest me to continue, i dont want super fast machine. decent speed will be nice to have though. will it work. please suggest any thing on basis of ur experiences
also i have issues with frequent power outages. for that i have come up with this solution
will keep a car battery as backup for spindle. spindle will switch to battery in case of power loss.. stepper motors will go off in power outage but spindle will keep spining for say 10 sec to protect tool breaking. will use timing relay for this purpose,, any suggestion will be welcomed
Re: need guidance on my design
please lrt me know any suggestions
- You may not post replies
- You may not edit your posts
Forum Rules
