New to the CNC world
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: New to the CNC world
    Jul 2017
    Default New to the CNC world
    Hello,
    I'm a small time mfg of electronic components for emergency vehicles. I'm in dire need for help selecting a small CNC routing machine to route notches on plastic boxes for production. At most, it would be on two axis, total work surface no more than 12" in both directions. Can anyone help me select / buy a machine for me? I'd love to have a setup where I can clamp down a piece, press "start" and it'll route two notches per box, then repeat.
    Sean
    Member KH0UJ's Avatar
    Jul 2016
    Philippines
    Default Re: New to the CNC world
    Well a 3 axis 6040 CNC will suit your needs, if you can post the exact measurements of your desired material you want to produce, I can post it back here the codes for it, all you have to do is bolt the material, Zero the spindle, load the code then start, and do it all over again a million times hehe just joking, I just need what bit size you want to use then I`ll post it her sir
    Jul 2017
    KHOUJ -
    Wow, that is very kind of you! The link for the boxes I will be routing (specifically, notching) is below. It's likely quite simple with just two axis to deal with (X & Y). Bit size is 3/16" with the ability to round the corners to avoid sharp ends. Image below is the board I'm fitting in the box. As you can see, the barrier strip is blocked. Hope this gives you a good idea. If you're asking for the X & Y dimensions of the cut, I'm not sure how I can get that info properly.
    https://www.polycase.com/bf-060210
    Attached Thumbnails Attached Thumbnails New to the CNC world-060210-jpg
    Jul 2016
    Philippines
    By just looking at your sample picture, are you referring to this cover? can you post a detailed measurements on what you want for the dimensions? if it`s so small I think the 1/8 bit is more suitable for the job so that you`ll have a smaller rounded edges, 3/16 will have a gap on the edges that the insects (ants) can go through.
    Attached Thumbnails Attached Thumbnails New to the CNC world-1111-jpg
    Jul 2017
    It won't be in an environment with ants and what-not. No cover will be used. It's automotive. I can get the exact dimensions soon but ballpark is around 10mm x 60mm for one notch and 10mm x 100mm for the other. I have another homemade notching setup for another that I use by hand and it's 3/16" itself and thought I'd keep it consistent. I'd imagine that a single pass is all that's needed.
    I looked at the 6040's. Is that the size of the work area? I wish I could find a book or take a class about this stuff. I find it fascinating.
    Jul 2016
    Philippines
    Quote Originally Posted by Aquamoose View Post
    Yes it`s 60 cm by 40 cm in measurement of the work area, if by chance you want to use an acrylic plastic I think the laser machine is more faster creating your project but a bit pricey compared to a more compact CNC router, It can be done with a single pass but just create tabs on it so that it wont come flying when the cut cycle is almost done, happens to me all the time few years back hehe, now im more clever cutting things
    About your project maybe just draw it by hand with detailed measurements, take a pic on it and post it here, let me do the rest. a small ruler can do the trick in measuring your desired measurements
  7. #7
    Jul 2017
    Quote Originally Posted by KH0UJ View Post
    My two notches... one is 10mm deep, 50mm wide, second notch 10mm deep (again), 58mm wide. I'd like to have the top corners "rounded" out to prevent scratching hands, etc.
    I plan to utilize a vacuum setup to suction up the shavings & tabs. I can also make a jig to hold the work in place either flat on the surface using X & Z axis (or is it Y & Z axis?) or on its side using X & Y axis.
    If I get this setup done, I'd like to play around with it, maybe use it for engraving. Of course, I'd have to learn about the programming. I just hope it's super easy for me. :-/
    Attached Thumbnails Attached Thumbnails New to the CNC world-060210b-jpg
  8. #8
    Jul 2017
    I should add...
    The "yellow" part is the area to be notched. The electronics will be encapsulated, covering the lower board and leaving just the through-hole components visible.
  9. #9
    Jul 2016
    Philippines
    Got it sir, I got the measurements I needed, I cant do anything right now because im here at the cnc shop, no internet, only my phone, i'll get back on this when im home
    Sent from my SM-J120H using Tapatalk
  10. #10
    Jul 2017
    Oh no problem! Thank you!
  11. #11
    Jul 2016
    Philippines
    Is this what you mean on your notch?
    Attached Thumbnails Attached Thumbnails New to the CNC world-02222-jpg   New to the CNC world-0111111-jpg
  12. #12
    Jul 2016
    Philippines
    This will be your table placement, secure it with table clamps. I made it two passes so that it wont be too aggressive.
    Here`s the code
    Code:
    ( T3 : 4.76 )G21 G90 G91.1 G64 G40
    G0 Z3.0
    ( T3 : 3.0 )
    T3 M6
    ( Notch 1 )
    G17
    M3 S1000
    G0 X0.0 Y0.0
    G0 Z1.0
    G1 F1600.0 Z-1.2
    G1 X0.161 Y-0.5407
    G1 X0.366 Y-1.0662
    G1 X0.6138 Y-1.573
    G1 X0.9026 Y-2.0576
    G1 X1.2304 Y-2.5167
    G1 X1.5949 Y-2.9472
    G1 X1.9938 Y-3.3461
    G1 X2.4243 Y-3.7107
    G1 X2.8834 Y-4.0385
    G1 X3.368 Y-4.3273
    G1 X3.8748 Y-4.575
    G1 X4.4004 Y-4.7801
    G1 X4.5459 Y-4.8234
    G1 X4.941 Y-4.941
    G1 X5.5889 Y-5.0769
    G1 X6.4213 Y-5.1459
    G1 X9.7623
    G1 X9.788 Y-53.703
    G1 X6.5262
    G1 X6.0601 Y-53.7223
    G1 X5.5003 Y-53.7921
    G1 X4.9482 Y-53.9079
    G1 X4.5517 Y-54.0259
    G1 X4.4075 Y-54.0688
    G1 X3.882 Y-54.2739
    G1 X3.3752 Y-54.5216
    G1 X2.8906 Y-54.8104
    G1 X2.4315 Y-55.1382
    G1 X2.001 Y-55.5028
    G1 X1.6021 Y-55.9017
    G1 X1.2375 Y-56.3322
    G1 X0.9097 Y-56.7913
    G1 X0.621 Y-57.2759
    G1 X0.3732 Y-57.7827
    G1 X0.1681 Y-58.3082
    G1 X0.0072 Y-58.8489
    ( Notch 1 )
    S1000
    G1 Z-2.4
    G1 X0.621 Y-57.2759
    G1 X2.001 Y-55.5028
    G1 X3.882 Y-54.2739
    G1 X6.5262 Y-53.703
    G1 X9.788
    G1 X9.7623 Y-5.1459
    G1 X6.4213
    G1 X5.5889 Y-5.0769
    G1 X4.941 Y-4.941
    G1 X4.5459 Y-4.8234
    G1 X4.4004 Y-4.7801
    G1 X3.8748 Y-4.575
    G1 X3.368 Y-4.3273
    G1 X2.8834 Y-4.0385
    G1 X2.4243 Y-3.7107
    G1 X1.9938 Y-3.3461
    G1 X1.5949 Y-2.9472
    G1 X1.2304 Y-2.5167
    G1 X0.9026 Y-2.0576
    G1 X0.6138 Y-1.573
    G1 X0.366 Y-1.0662
    G1 X0.161 Y-0.5407
    G1 X0.0 Y0.0
    ( Notch 2 )
    S1000
    G0 Z3.0
    G0 Y-95.5909
    G0 Z1.0
    G1 Z-1.2
    G1 X0.161 Y-96.0595
    G1 X0.366 Y-96.5149
    G1 X0.6138 Y-96.9542
    G1 X0.9026 Y-97.3742
    G1 X1.2304 Y-97.7721
    G1 X1.5949 Y-98.1452
    G1 X1.9938 Y-98.4909
    G1 X2.4243 Y-98.8069
    G1 X2.8834 Y-99.091
    G1 X3.368 Y-99.3413
    G1 X3.8748 Y-99.556
    G1 X4.4004 Y-99.7337
    G1 X4.5459 Y-99.7713
    G1 X4.941 Y-99.8733
    G1 X5.5889 Y-99.991
    G1 X6.4213 Y-100.0508
    G1 X9.7623
    G1 X9.788 Y-142.1352
    G1 X6.5262
    G1 X6.0601 Y-142.1519
    G1 X5.5003 Y-142.2124
    G1 X4.9482 Y-142.3127
    G1 X4.5517 Y-142.415
    G1 X4.4075 Y-142.4522
    G1 X3.882 Y-142.63
    G1 X3.3752 Y-142.8447
    G1 X2.8906 Y-143.095
    G1 X2.4315 Y-143.3791
    G1 X2.001 Y-143.6951
    G1 X1.6021 Y-144.0408
    G1 X1.2375 Y-144.4139
    G1 X0.9097 Y-144.8118
    G1 X0.621 Y-145.2318
    G1 X0.3732 Y-145.671
    G1 X0.1681 Y-146.1265
    G1 X0.0072 Y-146.5951
    ( Notch 2 )
    S1000
    G1 Z-2.4
    G1 X3.882 Y-142.63
    G1 X6.5262 Y-142.1352
    G1 X9.788
    G1 X9.7623 Y-100.0508
    G1 X6.4213
    G1 X5.5889 Y-99.991
    G1 X4.941 Y-99.8733
    G1 X3.8748 Y-99.556
    G1 X3.368 Y-99.3413
    G1 X2.8834 Y-99.091
    G1 X0.366 Y-96.5149
    G1 X0.161 Y-96.0595
    G1 X0.0 Y-95.5909
    G0 Z10.0
    G0 X0 Y0
    G0 Z0
    M5
    M30
    Attached Thumbnails Attached Thumbnails New to the CNC world-0123-jpg
  13. #13
    Jul 2017
    Yes! Exactly!!! You're gifted! Even the top radius to avoid sharp corners is perfect!
    By the way, thought I should tell you the spacing between the notches and from the sides... from inside corner, left side to right... 10mm, 35mm between the two notches, and 3mm from the right side. (156mm total)
    Now I just have to find a budget setup for this... I'd imagine that it'll need a computer to operate it? Type of program?
  14. #14
    Jul 2010
    Hello,
    I was trying to build a prototype that can make a Bernoulli spiral using paint. I want to use servo with encoders and I want to buy a plug and run set with a coding and path generator software. Anyone has any suggestions where to start and where to buy the parts?
    Thanks,
    MN
  15. #15
    Jul 2016
    Philippines
    The cheapest CNC I think that would do your looping notches is this >>> https://www.ebay.com/p/DIY-CNC-Route...d=302292473345
    Yes you need a PC to control it, an old HP pavilion will do the job perfectly. you just need to construct a custom bracket to hold your plastic.
  16. #16
    Jul 2016
    Philippines
    As for the software you can try UCCNC as recommended by my boss here or MACH3, either of the two.
  17. #17
    May 2011
    So you want a CNC machine to cut notches in a box over and over again for mass production?
    Is there any other purpose why you might want a cnc machine?
    How many boxes do you need to cut? These boxes are made of plastic right?
    The reason I'm asking is that I'd first consider making a jig and using a hand held router. You don't need a CNC machine to do this. It would probably be quicker with a jig even for one at a time work.
    If you have 1000's of these boxes to cut, then a jig that holds many boxes on the table of a CNC machine that would go from box to box cutting the notches, with 20 boxes loaded at once, perhaps yes, I could see that being worth while.
  18. #18
    Jul 2016
    Philippines
    Quote Originally Posted by NIC 77 View Post
    I think there`s a lot of things he can do on a CNC machine, not just notching plastics, like for example he got lazy etching his PCB on his product, he can simply load the unetched PCB (single sided or double sided) then start engraving the foil paths on it, then change tool bit into drill bit to drill thru the holes, it take the job easier with precision, engrave a LOGO on his final product things like that
  19. #19
    Jul 2017
    (gah, lost my previous comments)
    NIC 77 - Yes, mass production. All plastic boxes. That's primarily what I'd like to use it for. Maybe later, it will be used to do other similar projects, making notches, holes, etc.
    KHOUJ - I have a spare computer I can use for this. What's the minimum operating requirements? I clicked on the software and it wasn't valid. :-/
    I also saw that ebay link. I'm concerned about the ability to change bits in the motorhead. Are there alternatives available if I can't buy regular replacement pieces from my local home improvement stores? I've seen cnc machines with brackets to put your own corded Dremel in it... worthwhile?
  20. #20
    Jul 2016
    Philippines
    a dual core pentium would be all right, as long as there's an LPT1 port, dont buy the usb version, it'll give you headaches in the future, as for the bit on the router, you can even use a sharpened 1/8 concrete nail on cutting plastics, it uses a standard 1/8 collet, you can buy a separate 3/16 & 1/4 collets if you want to use larger bits, yuo can buy any cnc you want as long as it's a parallel port so that it will last to you a very long time
