Here`s the code for horizontal mount sir, it starts from right to left
Note: on our machines I dont use the homing switches, I just press "ref all home" button on mach 3 to zero all axis on it`s current position, I do think that it`s easier for you to reload materials if the plastic is facing the other way around, simpler to reach the T-slot brackets with wing nuts, on sacrificial wood, a 1/2 plywood I think is good enough to put your wooden stoppers and the upside down bolts for the T-slot brackets then wing nuts for easy load and reload of the plastic boxes but of course it all depends on your preference, bottom line is you can do whatever you want with it
Code:
( T3 : 3.0 )G21 G90 G91.1 G64 G40
G0 Z3.0
( T3 : 3.0 )
T3 M6
( Slot 1 )
G17
M3 S12000
G0 X0.0 Y0.0
G0 Z1.0
G1 F1600.0 Z-1.2
G1 X-0.5408 Y-0.16
G1 X-1.0664 Y-0.3656
G1 X-1.5717 Y-0.6144
G1 X-2.0566 Y-0.9014
G1 X-2.5162 Y-1.2289
G1 X-2.9453 Y-1.5945
G1 X-3.3439 Y-1.9931
G1 X-3.7095 Y-2.4222
G1 X-4.0371 Y-2.8818
G1 X-4.3265 Y-3.3668
G1 X-4.5728 Y-3.8746
G1 X-4.7785 Y-4.3976
G1 X-4.8216 Y-4.5449
G1 X-4.9384 Y-4.9384
G1 X-5.0755 Y-5.5859
G1 X-5.1441 Y-6.4187
G1 Y-9.7575
G1 X-53.6827 Y-9.7854
G1 Y-6.5228
G1 X-53.703 Y-6.0581
G1 X-53.7716 Y-5.497
G1 X-53.8884 Y-4.946
G1 X-54.0051 Y-4.5499
G1 X-54.0483 Y-4.4052
G1 X-54.254 Y-3.8796
G1 X-54.5003 Y-3.3744
G1 X-54.7897 Y-2.8894
G1 X-55.1172 Y-2.4299
G1 X-55.4803 Y-2.0008
G1 X-55.8815 Y-1.6021
G1 X-56.3106 Y-1.2365
G1 X-56.7701 Y-0.909
G1 X-57.2551 Y-0.6195
G1 X-57.7604 Y-0.3732
G1 X-58.286 Y-0.1676
G1 X-58.8268 Y-0.0076
( Slot 1 )
S12000
G1 Z-2.401
G1 X-53.6827 Y-6.5228
G1 Y-9.7854
G1 X-5.1441 Y-9.7575
G1 Y-6.4187
G1 X-0.5408 Y-0.16
G1 X0.0 Y0.0
( Slot 2 )
S12000
G0 Z3.0
G0 X-95.5538
G0 Z1.0
G1 Z-1.2
G1 X-96.0235 Y-0.16
G1 X-96.478 Y-0.3656
G1 X-96.9173 Y-0.6144
G1 X-97.3362 Y-0.9014
G1 X-97.7348 Y-1.2289
G1 X-98.1081 Y-1.5945
G1 X-98.4534 Y-1.9931
G1 X-98.7682 Y-2.4222
G1 X-99.0526 Y-2.8818
G1 X-99.304 Y-3.3668
G1 X-99.5172 Y-3.8746
G1 X-99.695 Y-4.3976
G1 X-99.7331 Y-4.5449
G1 X-99.8346 Y-4.9384
G1 X-99.954 Y-5.5859
G1 X-100.0124 Y-6.4187
G1 Y-9.7575
G1 X-142.0815 Y-9.7854
G1 Y-6.5228
G1 X-142.0968 Y-6.0581
G1 X-142.1577 Y-5.497
G1 X-142.2593 Y-4.946
G1 X-142.3608 Y-4.5499
G1 X-142.3989 Y-4.4052
G1 X-142.5766 Y-3.8796
G1 X-142.7899 Y-3.3744
G1 X-143.0413 Y-2.8894
G1 X-143.3231 Y-2.4299
G1 X-143.6405 Y-2.0008
G1 X-143.9858 Y-1.6021
G1 X-144.359 Y-1.2365
G1 X-144.7577 Y-0.909
G1 X-145.1766 Y-0.6195
G1 X-145.6159 Y-0.3732
G1 X-146.0703 Y-0.1676
G1 X-146.5401 Y-0.0076
( Slot 2 )
S12000
G1 Z-2.401
G1 X-142.0815 Y-6.5228
G1 Y-9.7854
G1 X-100.0124 Y-9.7575
G1 Y-6.4187
G1 X-96.0235 Y-0.16
G1 X-95.5538 Y0.0
G0 Z3.0
G0 X0 Y0
G0 Z0
M5
M30
Nice belt driven CNC machine you got there sir our two units CNC laser machines used belts too, and it`s already 12 years old and never change the belts on it yet. I do think it`s a clever way to avoid ball screw jamming due to small dust particles entering on it causing to lose steps, for light routing passes on non metal materials I think it`s a good and better idea to use belts instead of a ball screw
