So I've read that any material (including gas) cant heat up or cool down fast than another. All good. The rate of heating or cooling is dictated by the temp difference of each material. The greater the difference the faster the temp transfer. Conductivity of the matter effects the ability of the material to move the temp away from the connecting surfaces and thus keeping the temp difference greater.
Gases don't conduct temperature well at all however I'm interested to know if the air that is in contact with the material we are heating or cooling is kept moving, can we effectively move more heat away than that same material being in contact with a solid such as aluminium?
Interesting the conductivity of water vs aluminium here: Thermal Conductivity of common Materials and Gases.
Aluminium 205 vs Water 0.58.
Water is 1/400th as conductive of heat than water however a steady flow of room temperature water over a material will cool it much faster than simply putting a block of aluminium against it. So doe the same go for a steady flow of air, although less conductive than aluminium, will it cool better?
Happy Days
