- Problem sending data to Sabre 408 with art path
Greetings, I have a problem with the serial port communication, my Router Gerber saber 408, dont recognize the PC, I send the files from Art Path and they do not reach the router, probe with a tester the data cable and okay, can somebody help me , Thank you
Re: Problem sending data to Sabre 408 with art path
Often when using a PCI Parallel port card, the address of the card is not supplied to any program needing to access a Parallel port. Otherwise not enough information to suggest a fix.
- You may not post replies
- You may not edit your posts
Forum Rules
