Motor Tuning issues with MACH 3
Results 1 to 7 of 7
Thread: Motor Tuning issues with MACH 3
    Jul 2017
    Default Motor Tuning issues with MACH 3
    Hi All,
    I have some issues with Motor Tuning with my CNC i have built
    i am using the following
    Chinese break out board
    1PC 5 Axis CNC Breakout Board For Stepper Driver Controller Mach3 Power Module
    Stepping Motor Driver
    Single Axis CNC Engraving Machine Stepper Motor Driver Controller TB6600 0.2-5A | eBay
    And nema 34 Motor
    Nema 34 Stepper Motor 8.5Nm 5A 4-wire 14mm Dual Shaft DIY CNC Mill Lathe Router
    And Mach 3
    Step driver set to 1/16
    Ball Screw 8mm
    Pitch 2mm
    Steps 7000
    Velocity 100
    Acceleration 50
    Step Pule 0
    Dir Pule 0
    The strange thing i can't seem to work out why it is doing this.
    It work for a little bit sometime when i first boot it up and i can just jog the motor when i try to zero everything to run a simulation the motor step like 1mm per sec and sounds like it is struggling and is not tuned correctly.
    So I go back to setting and try Auto Tune and the motor seems to work perfectly again it will move the 20mm that i set it to. When i try jog with the Keys the motor it only moves at 1mm and struggles even thou i have not changed the motor tuning.
    I am not sure if i am missing something in Mach 3 or if my BOB is playing up.
    Any advice will be much appreciated.
    Nathan
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Motor Tuning issues with MACH 3
    First, set you step and dir pulse widths to at least 5. That should make a difference.
    Is this setup in inches, or mm's?
    What voltage is your power supply?
    You aren't likely going to get much speed out of this setup, as you have a motor that needs over 100V to work well, and you're drive can only supply half the current it needs. Combine that with a 2mm pitch screw, and it's a terrible compbination.
    A motor 1/5 the size would easily outperform the one you have.
    UCCNC 2017 Screenset
    Mar 2003
    Shelby Township
    If you are setup in mm's, you steps/unit should be 1600. (200steps rev x 16 microsteps / 2mm pitch)
    If in inches, it should be 40640. (25.4/2 x 200 x 1600)
    Not sure where you got 7000 from??
    Jul 2017
    Hi Gerry,
    Thanks for your reply,
    I am using it in MM
    and are using a 24 volt PSU as per the spec
    24V 15A 360W CNC Stepper Motor Driver Switch Power Supply 220V 110V TB6560 | eBay
    Manufacturer Part Number 34HS46-5004D
    Motor Type Bipolar Stepper
    Step Angle 1.8°
    Holding Torque 8.5Nm(1204oz.in)
    Rated Current/phase 5.0A
    Phase Resistance 1.0ohms
    Recommended Voltage 24-60V
    Inductance 11mH±20%(1KHz)
    Weight 3.9kg
    i am not sure i can put 100v in to the unit.
    Nathan
    Jul 2017
    Hi Gerry,
    I have changes it to 1600 and step and dir to 5 it once again worked great for about 5 mins and just struggled check out the 2 video below
    I have tried to hook it up to an Adruino and it seems to work fine with it stepping, so i can only think it is a MACH 3 or BOB issue.
    If you can think of anything else I might be able to change it will help.
    thanks
    Nathan
    Mar 2003
    Shelby Township
    Run Drivertest.exe in the Mach3 folder, and see if you get a flat line and steady pulse rate.
    Note that laptops are not recommended for Mach3 use.
    I would not expect to get any usable speed out of that combination of components you have.
  7. #7
    Jul 2017
    Hi Gerry,
    Thanks for your help, I ran it up on a PC and wouldn't you know it, the laptop was the issue.
    Thanks you so much for your help, now the motors seem to work at lot better I have them set the steps1600 and it spins up as it should i can play with the acceleration and get it working 100%.
    Thanks once again.
    Regards,
    Nathan
