- hass hs - rp
hass hs - rp
Good day I ask for your help since I have a problem with a machine haas horizontal of 2 tables.It turns out that to make the change of table or pallet is occupied a program that in memory is the O9000Which is read when you execute the code M50, the situation is that by mistake the operator deleted the programAnd I do not find it anybody of you will have an equal machine and I can pass the program ofBeforehand they would be much pleased.regards....
Re: hass hs - rp
I cannot help with finding your program, but the HFO should be able to help. In the future keep setting 23 on, (9000 program protect) so it can mistakenly be deleted or changed.
- hass hs - rp
- You may not post replies
- You may not edit your posts
Forum Rules
