- Need Help - Fanuc 15T Write Protected error
Hello Guys, I'm using Nakamura Tome TMC-30 with Fanuc 15T control. I'm having a problem each time I try to edit, remove or add a new program, it gives an error of "Write Protect", any suggestions?
Flies Fast
Re: Need Help - Fanuc 15T Write Protected error
What are the program numbers you have for those programs ?
If they are in the O8000 to O9999 range , they are in a protected number range, access to the "sensitive" programs is permitted by changing a parameter
( these programs tend to be macros, etc, that have been proven to run correct, and not be available to be altered by inexperienced operators, nor be deleted ) ( ie measuring, probing macros )
- use numbers lower than O8000
Sir I have just 3 programs in my machine, O0001, O0002 and O0003.
Flies Fast
Have you searched to see if the solution has been posted previously ?
ie http://www.cnczone.com/forums/showth...rite protected
or http://www.cnczone.com/forums/showth...controls this?
Does the control have a "Program Protect" switch ?
- You may not post replies
- You may not edit your posts
Forum Rules
