- Askpower a131 (VFD) + mx4660 + mach3
Looking to see if anyone else has this configuration, mainly need help controlling the spindle from Mach3, I'm not sure if my VFD is set correctly. I have tried a few things I found on here, but with little luck.
Mx4660 to VCD
EGND > GND
+10Vdc > 12V OUT (From MX4660)
0-10V > 10V IN
OUTPUT1- > GND
OUTPUT1+ > FWD
Mach3
Motor Output: Spindle on, 14, 0, x, x, 1, 1 (Pin 14 is the PWM Signal on MX4660)
Output Signal: Output #1, 1, 17, (Pin#17 = OUTPUT#1)
The VFD is configured as follows (These are the only setting I have changed) as of now it powers up with all 000.00
Pn03=4
Pn04=2
- You may not post replies
- You may not edit your posts
Forum Rules
