CNC not cutting parts to size in which drawn
Results 1 to 6 of 6
Thread: CNC not cutting parts to size in which drawn
    May 2017
    Default CNC not cutting parts to size in which drawn
    I run a Standard 3 axis 5' x 12' CR ONSRUD CNC machine. Using both Alphacam R16 v 2 and Cabinet vision.
    Cutting countertops and they were cut small using a half inch DC, by a half inch in both the X and Y. I tried a test piece and it did the same thing. I shifted my 0,0.
    I have checked my table and the CNC itself is fine. I moved it without a program from x0-x50 and it was spot on, the same as in the y. Any helps on where i have alterted the program?
    Dec 2013
    Default Re: CNC not cutting parts to size in which drawn
    Is the tool size size correct in the CAM program?
    May 2017
    It is. Ive brought up an old program and ran it without touching any of the configurations and it worked fine.
    Dec 2013
    That is what I was suggesting. From what you describe it would seem that the tool size is not entered into the new program. Using a 1/2 inch diameter tool that is set to 0 diameter in the new part program would give you a part that was 1/2 inch small in both axes. Sounds like your machine is doing exactly what it's being told to do.
    Registered Miz's Avatar
    Sep 2011
    United Kingdom
    Quote Originally Posted by Jim Dawson View Post
    Or the tool diameter is correct, but compensation has not been set/used.
    May 2016
    Enter the tool size into the offset in your settings. Using G42 or G41 will make programing much easier I have found. If you grt confused on G42 or G41 just imagine you are walking behind the cutter. If the cutter or tool is on the right side of the path drawn then it will be G42. If you want the tool on the left side of the tool path then it's G41. Be sure to cancel the tool comp using G40 once part is cleared.
