1) Outsourcing. Does anyone know of a company that cuts and engraves (or laser marks) fine metals for small businesses?
[That sounds like at least 3 different companies. If you want shapes cut out, you would need to find someone to make the dies, then send them somewhere else for stamping out the pieces. You'd probably want to have the engraving or laser-marking done before you did that, since it's hard to hold onto small delicate pieces without marring them.
Dar Shelton
Sheltech | affordable custom dies for cutting out parts that you design has made a business around producing "pancake" dies for jewelers; I believe he will also use them to cut out pieces for you; you could ask about that. You could also get a hydraulic press and stamp the pieces out yourself.
Laser marking is pretty common in industry; here's a company in the SF Bay Area that does it on a custom basis:
Laser Marking, Laser Engraving, Laser Etching You might have to look around for someone that specializes in jewelry, though.
The other way to go, if you don't want to do it by hand, is with mechanical (also called "rotary") engraving. This requires a CNC-controlled machine with a fast spindle, and allows the operator to load image files which are automatically cut into a range of materials. Here's an article about it:
https://www.engraversjournal.com/art...975/index.html I don't know who's offering this as a service to other jewelers; most shops do this as a retail business. But I'm sure there are places in Rhode Island that will do it for you, if you can't find anyone local.]
2) If I go on my own, can a small CNC machine do the work? I want to cut 18 gauge metal 1.02mm. Which machines would you recommend? My price range is probably around 3-4K. Since I do not know anything about CNC, I would appreciate as much detail as possible on the equipment (name, model, limitations, etc).
Any help you can provide will be greatly appreciated.
Gloria
