I have been looking at bigger machines hoping to scale down to my size.
Hi.
My name is John, and have been working with CNC machines more than 7 years.
Now I want to build a big 3-(4-) axis CNC router to carve steel (and lighter materials).
Machine design it's not my forte and because of that I feel the need to discuss design with the people that come from a more experienced background when it comes both to design and machining.
I am building a garage with a upstairs room/workshop at home.
Limitations:
#1: Due to building restrictions my upstairs will be only 1,89 metre tall.
#2: Weight. Due to building limitations of the garage, the machine can be max 1000kg, and say a work piece of about 500kg.
#3: Size. The room will be about 6,6x4 metre, there will be stairs for access, a door to a storage room and a work bench, so moving gantry router seems the way to go.
#4 Power supply. 230V 63A due to wiring to my house.
The idea is to build a machine capable of precision work, that can do hard machining in steel and have some degree of speed to it.
I want to be able to line bore a engine block, facing, headwork, make a cast engine block?
Accept small series of work for companies and others. Tapping of M16-M20 thread.
Try to make it flexible for most jobs out there.
Double duty as a lathe? (4th-axis)
A lot of wishes but challenging limitations.
First off, what do you think?
-John-
It is not clear for me if you want to build your CNC upstairs or on the ground floor. But...
That's a HUGE machine, especially if you want to make it metal machining capable. I don't think that it can be made as light as you want it with those dimensions and capabilities. Metal machining 1200x2000x500mm requires a huge mass and I don't think 1t is enough, especially if by "metal" you mean steel, but in that size even milling aluminium would be a challenge.
https://www.youtube.com/c/AdaptingCamera/videos
https://adapting-camera.blogspot.com
Yes, I certainly have doubts in regards of size. Mass is the key-word in stability for roughing passes and precision work.
Maybe a horizontal mill design will do better here, the Y-axis can extend to the roof, the Z-axis can be longer due to working on short lengths except long bores etc.
For a 1000x1000xx1000mm work area the machine should be be able to fit into 2500x2000mm of space, and as close to the roof as possible. I can still do what I want to. That is acceptable.
Then there is weight. Is it possible to make it rigid enough within my limitations to run reasonable cutting data?
I got a deal with a local shop to borrow their tools and machines to fabricate parts.
I am building a 1000kg lifting arrangement and a opening from the main floor to the attic, to move stuff up and down.
Hello fellow Norwegian !
I have also been looking into designing and building a CNC machine for similar types of work. I ended up purchasing a vintage used machine. If you are lucky you can find a used machine that is mechanically sound. But might need to upgrade the electrics. Below i have listed a few sites that sells new and used machines usually for reasonable prices.
ltsmaskin.no
prmaskin.no
metalsupply.no
finn.no
I think that a machine that have a 1000*1000*1000mm work area and is going to machine metals without scattering is going to weigh several times more than 1000kg
-Mathias
Hello!
Thank you for your addresses. I have been looking around for used manual equipment, but to get a useable work-area, machines get too tall and heavy to fit my needs.
Last night I made a drawing with a horizontal milling design.
It went fairly well, ended at 850kg for the main structure and z-axis ram.
Then I added a 800x800x50mm steel plate for rigid x-axis, it came out at 260kg. Still ok-ish.
But, my choice of a 1000x1000x100mm work table that double duty as a rotary lathe-table ended at around 800kg alone!
Rotating that amount of mass, add a workpiece, possibly little out of center.. And I start worrying about the integrity of the main structure in the garage!
I got to drop the lathe-function here, as long as the machine is not bolted to a concrete foundation. A rotating b-axis should help mill most of the stuff that need turning.
So, around 1100 kg+ 1000 mm square work table(aluminum?), drives and other hardware..
I am hoping for a total design of around 1500kg.
I am making a drawing, trying to scale the machine.
Is a 90mm shaft sufficient to support the 1000x1000x100mm aluminum work table on the rotating b-axis without flexing machining at maximum distance away from the connection point?
Is there a way to calculate the required shaft size without the trial and error approach?
Cheers.
-John-
Hi guys.
I have been tinkering with two different designs. One that will let me have a work envelope xyz of 1000x1000x900 the one in the drawing and one router design with a xyz 1000x1000x750mm.
For this one I've made a drawing to get a idea of scaling and how it need to look, and weight.
What do you think?
-John-
