Why not use the fusion cam it is better than vectrics.
A file to look at would be better than a vid
Hi everybody here is the problem I am having Im trying to cut HDPE for the first time I id my design on Fusion 360 then exported it to Aspire to do my toolpaths. But when I run the preview it shows me that im cutting the edges. Ive attached a link to video for better explanation.
My Setup:
Shark Black Diamond Router
Fusion 360
Aspire 4.5
https://www.dropbox.com/s/nbuevlwzex...85556.mp4?dl=0
<img src="https://ivxo1q-dm2305.files.1drv.com/y4mENMmTr_Cabc7pR0FUdB6gtbADq2JbuG4_rGy0eBQvLJx19pTi6TqMUIJN0xgOyDIc0gWoxYhS38HpbSTFGdfaK-o42IOU6jczrhDpfpCOTNGL1X6hvZCbgj0y35gqmq1YGTrWwShYGV-C7lXA2esy0Pi_WfnBSyroDLSGXwce4uSr1U7op7srdi78rispHCa_K4aFlTlJPVkkNWMfgh_Tg?width=60&height=60&cropmode=none" width="60" height="60" />
Being Disabled is OK CNC is For fuN
Edit:
Simply do a profile path machine job, set either inside, on, or outside along the vectors, which would be vastly more efficient than doing it a as a 3D finish machining.
cheers, Ian
It's a state of mind!
If your part consists of all 2D machining, you don't want to bring a 3D model into Aspire. In Aspire, you only need to draw three rectangles and use a pocket toolpath.
If you want to create toolpaths for 3D models, then do it all in Fusion 360.
UCCNC 2017 Screenset
