- multicam 5000
multicam 5000
Hi, I am Joevani from phiippines currently staying here in dubai since 1998 being a cnc cadcam machinist and 3d artcam designer. i have some questions regarding the partprogram I am using ArtCAM software and saving in this extension files MultiCAM Toolchanger (inch)(*.plt) the multicam 5000 doesn't change the rpm automatically using 1 is endmill 8mm rpm18000 then 4mm drill bit rpm4000 he disregards the rpm he continues to use rpm18000.
- multicam 5000
- You may not post replies
- You may not edit your posts
Forum Rules
