- Australia New Member seeking and the sharing of info in my goal
Hi I have been using my CNC router for several years - main use is cutting Carbon fiber sheet. we make our own commercial drones using the cut Carbon fiber form and 3D components for the rest off the structural design. We get a reasonable finish using 2mm Diamond Cut Carbide Router Burrs. But would like to be able to investigate the use of Laser cutting as a more cleaner and efficient format.
Regards Barry
Re: New Member seeking and the sharing of info in my goal
I tried cutting carbon fiber sheet on a laser machine, it looks horrible with the burn marks, even worse on a galvo laser, I think it`s cleaner to cut it in a carbide bit
Thanks Khouj - I was hoping for a better solution but it comments such as yours that have been and tried are of great value - thanks for your time king regards Barry
- You may not post replies
- You may not edit your posts
Forum Rules
