- Newbie looking to bond with Dad over some metal chips.........
Hi Guys,
I just joined because I'm considering the purchase of a G0704 that will eventually get CNC converted.
My Grandfather and Father were both machinists and while my Dad is still around, I want to do some small projects/minor gunsmithing with him and maybe some bonding over some metal chips.
I currently have a Smithy 3 in 1, that while better than a drill press for a lot of the small projects I enjoy, it's not much better and it's a little tired.
Can someone tell me if there's any need advantage of purchasing the machine with the DRO from the factory if I'm going to be eventually (1-2 yrs) be converting the Mill to CNC?? Or is the DRO a waste of money at that point?
Re: Newbie looking to bond with Dad over some metal chips.........
One of the main reasons I go to my router instead of using my manual mill is that, on the router, I don't need to count revs and ticks on the scales. It's lazy but it's also a bunch of maths you're always doing and an opportunity every cut to lose count or just get the calculation wrong in your head resulting in a pass too short or too long and a wrecked part.
If it's going to be a couple years and it's only a few hundred bucks to get the DRO, get the DRO. You can always chuck 'em on eBay and recoup some or most of the cost when you convert.
- You may not post replies
- You may not edit your posts
Forum Rules
