Annealing Belt Furnace
Results 1 to 8 of 8
Thread: Annealing Belt Furnace
    Feb 2017
    Indonesia
    Unhappy Annealing Belt Furnace
    Hi, im new engineer. I need your help for my problem annealing furnace.
    Temperature of the furnace can't be decreased, so we dismantled the machine and found that the heater is cracked and broken. And we also found that muffle has bulged. Do you know what makes that happen? And how to solve it? Should i change the heater? Or change the muffle?
    Thx,
    Attached Thumbnails Attached Thumbnails Annealing Belt Furnace-img20170113142355-jpg   Annealing Belt Furnace-img20170113142348-jpg   Annealing Belt Furnace-img20170203175133-jpg   Annealing Belt Furnace-img20170203174124-jpg
    Dec 2013
    Default Re: Annealing Belt Furnace
    The only thing you can do is replace the damaged parts. Over time this will happen. Rebuilding the furnace is part of normal maintenance. I have repaired a lot of high temperature furnaces, it's just something you have to do when they are damaged.
    Feb 2017
    Indonesia
    Thx, before,
    In your opinion what caused that makes the muffler bulged and the heater cracking? When we dismantled the furnace, the muffler touch the heater because the muffler had been bulged. Whether it is causing the heater was broken?
    Sorry before,for my bad english, i hope you understand.
    Dec 2013
    Your English is good, no problem there.
    It is not possible to keep the muffle from being damaged when operating for a long time. The heat will damage the parts, there is no way to make it better. Possibly using different materials would help, but nothing will last forever.
    Feb 2017
    Indonesia
    Sir, you are an expert in this field, i have many question to ask about muffler. I want to buy new one, but i must present to my boss. I want give my slide to you and see what my problems. Can you give me your email address?
    Dec 2013
    I sent a PM with my email address
  7. #7
    Feb 2017
    Indonesia
    Thank you sir, i have already sent to your email.
  8. #8
    Feb 2017
    Indonesia
    Thank you sir, i have accepted your message
