- AP100US 2016.1 Software NC Code
We have an Amada Aries 245 currently using the above software. I came into the job with no prior experience or training and had no part in its initial setup. I used to be able to run a full sheet of parts on the press without any memory overflow errors. Upon upgrading the software my NC Code is substantially larger than it was before on the AP100US 2010 version. The overflow error is due to the size of the file, I want to say between 5k-7k bytes is the limit that can be sent to the machine at once. I don't exactly remember if the NC files being generated before the upgrade had macros in the code or not, so I couldn't tell you. Could anyone possibly enlighten me as to why the NC code would have changed? It is really annoying and time consuming for me to keep having to break the NC files down into multiple programs.
- You may not post replies
- You may not edit your posts
Forum Rules
