- need help with Fanuc otc control
Hello, I lost my parameters when the spindle drive went out of my Daewoo 8S. I had the drive repaired and when I reloaded the parameters all works well except it does not hold near the programs that it used to hold in the program file. Is there a parameter that cab be changed that will make this machine hold the amount of programs that it did before it went down? Thanks
- You may not post replies
- You may not edit your posts
Forum Rules
