- Haas background edit
I am trying to access the background edit while the program is running. I want to be able to edit G code in feed hold, then start the program again from the same block of code I was on. Haas website says that after I press edit( while the machine is running) that the background edit will become active, my machine says "wait or reset". Is there a setting number that is not allowing this function to begin? I have gone through the settings and did not see anything. Thanks any feedback is appreciated.
- You may not post replies
- You may not edit your posts
Forum Rules
