North America MasterCam doesn't post toolchange when "enable tool stage routine" enabled.
Results 1 to 4 of 4
Thread: MasterCam doesn't post toolchange when "enable tool stage routine" enabled.
    Jul 2015
    Default MasterCam doesn't post toolchange when "enable tool stage routine" enabled.
    Posting from MasterCam X6 to Fanuc 16i . When I go and check "enable tool staging routine" in controller, M6 T# doesn't occur if only posting a single tool. Here is my post processor. Appreciate any help.
    Attached Files Attached Files
    Jun 2015
    U.S.A.
    Default Re: MasterCam doesn't post toolchange when "enable tool stage routine" enabled.
    tell me if this works please
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    Quote Originally Posted by RuckinFugger15 View Post
    If your attempt is just a little fun....I suggest you go and play games elsewhere...say, the middle lane on the freeway
    Code:
          "%", e$
          *progno$, e$
          "(PROGRAM NAME - ", sprogname$, ")", e$
          "(DATE=DD-MM-YY - ", date$, " TIME=HH:MM - ", time$, ")", e$
          "(you really want all that in there ^^?)" e$    <--- this is your addition
          pbld, n$, *smetric, e$
    mayhew1......ignore the previous posters attachment.
    normally for a single tool program, you load the tool ( into spindle ) before running the code. The machine is not continually checking / loading the same tool ( to save time )
    but there can be reasons to ensure that the correct tool is loaded before running code
    so find in the pst file and do the highlighted change ( one place only )
    Code:
    psof$            #Start of file for non-zero tool number
          pcuttype
          toolchng = one
          if ntools$ = one,
            #skip single tool outputs, stagetool must be on
            #stagetool = m_one     # comment placed to stop stagetool value being change to -1
            !next_tool$
          "%", e$
          *progno$, e$
          pcom_moveb
          c_mmlt$ #Multiple tool subprogram call
          ptoolcomment
          comment$
          pcan
          if stagetool >= zero, pbld, n$, *t$, "M6", e$   # if stagetool is -1.... then this line is not executed
          pindex
          if mi1$ > one, absinc$ = zero
    Jun 2015
    U.S.A.
    that's not all I changed superman. no games. just a question.
MasterCam doesn't post toolchange when &quot;enable tool stage routine&quot; enabled.
