rotary scratches on Aluminium
Results 1 to 3 of 3
Thread: rotary scratches on Aluminium
    Jul 2016
    Default rotary scratches on Aluminium
    I've only every milled aluminium with a spray mist/coolant/lubricant.
    Yesterday I used a machine that didn't have this and so splashed oil on everything with a paintbrush.
    Afterwards noticed that there was a lot of rotary scratching on the faces of the material.
    Was that because there was no spray mist?
    Or was it for some other reason (it's true the mill had a max rpm of only 3000 but slowed the feed accordingly as per Gwizard).
    Jul 2016
    Default Re: rotary scratches on Aluminium
    Not getting very far with this! May I put the question another way?
    What factors increase circular scratching when milling Aluminium?
    And what can be done about it?
    Thanks!
    Jun 2010
    Sounds more like a worn cutter.
    Cheers
    Roger
