General MetalWorking
Page 1 of 2 12 LastLast
Threads 1 to 20 of 27
Forum: General MetalWorking
Discuss Metal working here!
  1. Build Thread- vmc cnc milling machine with cast iron body
    Started by omid_king‎, 06-18-2017 05:23 PM
    11-19-2017, 09:28 PM Go to last post
    10-27-2017, 10:10 AM Go to last post
  2. Who posted these photos
    Started by Devashish‎, 09-11-2017 02:57 PM
    find, photos, tapatalk, a7000-a, lenovo
    09-12-2017, 01:28 PM Go to last post
  3. Fixtures / Soft jaws questions
    Started by FoxCNC1‎, 07-10-2017 12:29 PM
    cnc, guys, jaws, part, soft
    07-10-2017, 12:29 PM Go to last post
  4. Unhappy Need Help!- Casting Color change from Silver to Dark Grey
    Started by techmach‎, 06-22-2017 02:57 PM
    alumininum, blasting, color, diecasting, grits
    06-22-2017, 02:57 PM Go to last post
  5. Cutting Silver
    Started by VisualConduct‎, 12-05-2016 04:21 PM
    cutout, god, kind, make, silver
    12-05-2016, 05:55 PM Go to last post
  6. Cutting alloy fail
    Started by BLarks‎, 10-29-2016 10:04 PM
    2 Pages
    1 2
    11-05-2016, 08:15 AM Go to last post
  7. Adapter Plates for Tormach Table
    Started by Paul-JB‎, 10-25-2016 08:09 PM
    cnc, tormach, make, work, plates
    10-25-2016, 08:09 PM Go to last post
  8. Wall thickness using Aluminium
    Started by swimster‎, 09-29-2016 07:15 AM
    09-29-2016, 06:33 PM Go to last post
  9. *NEED HELP* machining pure molybdenum
    Started by vladp‎, 06-30-2016 03:40 PM
    center, grooves, part, pure, turnig
    09-27-2016, 05:08 PM Go to last post
  10. rotary scratches on Aluminium
    Started by maker4444‎, 08-08-2016 03:15 AM
    aluminium, mist, reason, rotary, spray
    08-12-2016, 06:49 AM Go to last post
  11. Need Help!- Milling kapton tape ?
    Started by tony978‎, 04-18-2016 11:56 AM
    tape, milling, kapton, tony, iphone
    04-19-2016, 01:37 PM Go to last post
  12. Cool Play with laser - Ladybird
    Started by Syd7‎, 04-13-2016 05:45 AM
    04-13-2016, 05:45 AM Go to last post
  13. Need Help!- tapping 2024 t351 alluminum
    Started by KENWILD1‎, 10-08-2014 08:34 AM
    000rpm, 1/4, 351, art, feed, haas, ipm, machine, max, mill, mos, point, push, rigid, rigid tapping, rpm, run, running, speed, spiral, star, start, tap, tapping, taps
    04-02-2016, 01:53 AM Go to last post
  14. how to mill angle iron flat on all sides.
    Started by matridium‎, 12-14-2015 03:46 PM
    3/8, angle, mill, surface, table
    04-01-2016, 04:16 PM Go to last post
  15. Benchtop buffer Hp?
    Started by jonkzak‎, 11-04-2014 12:28 PM
    3450, bench, benchtop, buffer, buffing, building, formation, hand, hat, information, input, motors, multi, put, reading, rpm, safe, sew, thinking, wanted, wheel, wheels, working
    04-01-2016, 05:28 AM Go to last post
  16. Need Help!- steady rest, manual lathe runout issue
    Started by 60rock‎, 09-01-2015 05:48 PM
    bores, o.d, rest, steady, tube
    04-01-2016, 05:16 AM Go to last post
  17. Question cutting aluminum plate with CNC router
    Started by totwgben‎, 03-15-2016 11:50 AM
    alumininum, cnc, cnc router, newbie cnc diy, newbie needs help
    03-15-2016, 12:00 PM Go to last post
    05-24-2015, 08:40 PM Go to last post
    02-18-2015, 07:01 AM Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 1 users browsing this forum. (0 members & 1 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
