machining 304 stainless steel
Results 1 to 20 of 20
Thread: machining 304 stainless steel
    Apr 2004
    NY
    Default machining 304 stainless steel
    I've got some exhaust manifolds I have to CNC from 304 stainless. I've gone through the machinist handbooks and it seems you need feed rates of .2/min. Any suggestions on tooling or lube to speed up the process? I have a feeling HSS bits will dull quickly so I was thinking of carbide. Thanks
    Paul
    Registered Konrad's Avatar
    Oct 2003
    Edmonton Canada
    Feed Rate all depends, on what tooling you are using, Carbide, HSS, long short, depth of cut, how many flutes, riggedy of your mill etc.
    I sometimes go as fast as 16"min.or .2" min.
    See, if you can mill {rough out with a roughing millingcutter first, the 304 is not bad cutting, in the 3....series, just make sure, you are not overheating, lots of coolant.
    Konrad
    Jan 2005
    Don't dwell, and use enough feed so you don't work harden the material. Use lots of coolant.
    Registered ghyman's Avatar
    Feb 2005
    I've had excellent luck with either cobalt or carbide drills and mills, but with TiALN coating... it's a little pricey, but it eats through 300 series like nothing else!
    Try 50 SFpM, and about 1.5-2.0 Ipm.
    And, as stated by everyone else... COOLANT!!
    Member whiteriver's Avatar
    Aug 2003
    Cuts like butter if you go fast enough. Cut it to slow and its like cutting a diamond with a butter knife. Will work harden in less than a second.. Keep the feed constant.
    Donny
    www.whiterivermfg.com
    Member Halfnutz's Avatar
    Feb 2005
    OK, coolant I get the message. I would love to flood everything I do. I just bought a round collum benchtop and since I do a lot of work with steel I am having problems with overheating. I cant figure out how I am going to deal with this in the long run. Any ideas on a benchtop flood system?
    Halfnutz
  7. #7
    Jan 2005
    Halfnut,
    Have you tried a mister? I have a couple of machines that don’t have flood capabilities and I use misters. I like the type with two nozzles and a reservoir with the controls on the reservoir. I have one called “Spray Master” that I like well enough.
    There are enough cutting fluids on the market to confuse anybody. I have found one called “Trim Sol” that I like very much. I use it in my CNC for flood but I also use it for my misters. Mix it about 5 to 7 parts water to 1 part “Trim Sol” and use enough air to evacuate the chips and enough fluid to make things wet, maybe not dripping but wet. This will help you with your steel cutting and heat problem.
  8. #8
    Feb 2005
    Default Kiddy pool & pond pump?
    Thanks for tip. No I hadnt thought about misting, but it sounds like the way to go. Until now my milling has been limited to a little Homier 12 spd. which is a great little machine, but not capable of creating the heat and piles of swarf that the 33686 does. What about a kiddy pool, some shower curtains and a pond pump? (just kidding)
    So about fluid choice,, is oil a thing of the past? Everyone is using water based coolants now? Is oil limited to threading? (I started out with a lathe and oil has allways been sufficiant).
    Halfnutz
  9. #9
    Feb 2005
    I have become a "swiss guy" over the past 8 years; there seems to be nothing a M32 can't do (shameless plug for Citizen!). As such, I have had the opportunity to run oil (in ALL my swiss machines), and water-soluable (in everything else).
    I have found better tool life in the swiss machines, but I think that is primarily due to the rigidity of the machines. I think the oil is also a factor, but I can't swear to it -- the right water-soluable coolant is pretty good too!
    As far as a mister goes, I think it depends on how big of a mess can you stand... My experience is that a water-based coolant in a mister leaves a nice 'scum' on everything around the area after a month or so... water evaporates, and leaves the mung behind. A light oil mist will work just as well, but the area needs mopped, wiped, etc. fairly regularly. (But everything is all nice and shiny!! )
    On a small mill, I bought a small pump and reservoir (2 gallons), and had pretty good luck with a "duct tape and bailing wire" plumbed flood system for under $100.
  10. #10
    May 2004
    Hello. I don't know much about metals but I believe 304 stainless steel does not harden with heat. I just finished doing quite a bit of 304 cutting and had no problem using cheap HSS cutting tools. I did take very small cuts however. For 'coolant' I used Tap Magic and water on a spray bottle. A quick squirt once in a while worked.
    I have heard good things about this system. I don't have one yet but plan to get it soon. This one also looks good.
    Julio
  11. #11
    Jul 2004
    Spring Hill, Florida
    Halfnutz,
    In my never to be humble opinion, Flood is far better than misting, especially for the home machine type guys. I picked up my flood system and coolant from Enco (www.useenco.com). The flood system was around 80.00 or so (been a few years - 5 gal tank, pump, tubing and drain stuff). I saw that Harbor Frieght has one that sells for 30 or 40 bucks. I used the water based coolant (ValCool). It does not funk up the garage with mist either. There are drawbacks to both types. You will have to drill a drain hole in the table top, use as large a drain as you can get in it. You will want to do a "splash guard" around your machine but it does not really take much.
    Again, flooding will net you cooler parts. Better in the garage or basement than misting and the cost is a wash. Good luck!
    Regards,
    Glen
  12. #12
    Feb 2005
    Default Five dollar flood
    BigDaddy,
    Check out this simple settup from about 5-10 dollars worth of misc. parts. It works great and I can set it to flood or mist. Do you leave water based coolant on your machine or do you mop everything dry when done? I know its suposed to be okay, but something about a water base emulsion sitting on my pretty polished table just bugs me. Have you ever had any problems with corrosion or rust?
    Attached Thumbnails Attached Thumbnails machining 304 stainless steel-fivedollarflood1-jpg   machining 304 stainless steel-fivedollarflood2-jpg   machining 304 stainless steel-fivedollarflood3-jpg
    Halfnutz
  13. #13
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    If you chose youre coolant carefully it will not rust the table.
    I have found the "milky" coolant to be best in that department.
    I must have tried a dozen different kinds when we started business.
    www.integratedmechanical.ca
  14. #14
    Mar 2005
    canada
    I realise that its expensive, but if coolant is a problem try replacing endmills with insert cutters and run them dry, they will give you better tool life.
  15. #15
    Jul 2005
    We run 304 s.s all the time , coolant works , but cutting oil works better . As for the mist probably wont keep the tool cool enough . Best choice for 304 is carbide tooling coated.
  16. #16
    Mar 2005
    Toronto, Canada
    Quote Originally Posted by DareBee
    any brand recomendations? i've been using cooltool, its ok, but wondering if i'm missing something better
  17. #17
    Feb 2005
    Oh, boy! you've just opened a can of worms...
    I think coolant preference is the biggest arguing point ever.
    IMHO, when it comes to stainless, you'll be best off if you can find a high-sulfer content coolant as a good starting point. Some manufacturers even offer a sulfer additive. (Check your local regulations when it comes to disposal!)
    Blaser is expensive but very good in both types; oil and water soluable.
    Cimcool is cheap, pink, and stinky.
    Hangsterfers is pretty good oil, but it has a very "odd" smell (gives me a headache!)
    There are some good synthetics, too... but also very pricey.
    Find some nearby tool supply houses, and ask them who they rep for. A lot of times, you can get a free fill-up of the latest and greatest from some of the manufacturers, as long as you provide a tool life analysis in return.
  18. #18
    Mar 2005
    Toronto, Canada
    hehe, didn't mean to or intend to hijack - just always interested in the professional perspective. i don't cut enough stainless to even form an opinion - thx for input
  19. #19
    Jul 2005
    We use blaser coolant , very good stuff doesn't get smelly. In our swiss machine's we use Hangsterfers , i think it has a great smell (just my thought though) ,both are expensive , but both are excellant for machining and they both are non-allergenic. You will get better tool life using oil though if that is a problem. Using cheaper coolants are hard on your ways, the cheaper stuff is just not slick enough and dries and your ways.
  20. #20
    Aug 2004
    Just checked...looks like JRoque is correct....besides he just machined a spindle from that stuff.
    Ouch on those 2 coolant dispensers 400 to 900 $....yikes....I like the cooland in the spray bottle...
