Need Help! Help with Double lead Thread
Results 1 to 1 of 1
Thread: Help with Double lead Thread
    Mar 2011
    Default Help with Double lead Thread
    Can I cut a double lead 2-56 UNC 2b thread with a thread mill
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    Default Re: Help with Double lead Thread
    yep, should be possible ! you need a helix soubroutine, that begins at a random angle, or shift Z kindly !
    ps : if you use a custom toolpath, that reduces tool stress when entering the material, than you will have to rotate also this type of operation
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
    Jun 2015
    Antarctica
    another way 2 do it is by using a temporary coordinate system : declare the program origin in the center of the bore and apply a rotation of 180 degrees ☺
