We are turning 1018 and getting lots of stringers. Our New GM doesn't like to see them in hoppers, but in the past it has always been a problem with this gummy material. We have tried a lot but not every insert out there, we use mostly Iscar or Tungaloy WNMG 432 or DNMG 432 inserts. We normally are cutting .100 per side, 6oo sfm and .010 fpr. Any thoughts on eliminating the stringers? Thanks
1018 can be extremely gummy and can be very tough to break a chip. The chipbreaker I have had the most luck with to break chips in 1018 is the Kyocera XS Chipbreaker. Kyocera has a series of chipbreakers designed to break the chips in gummy low carbon steels, here is an image showing their top chipbreakers for low carbon steels depending on DOC
