I would say speed too fast and no coolant would be the culprit otherwise blunt cutter.
Anyone ever experienced this when drilling through aluminum?
This is on the backside. Been running at 5200 RPM, 1/8" thick, rapid out drilling with a 1/4" tool. Don't use any coolant (doing this on a cnc router) but I do have air blast on it. I managed to make a few good pieces but just broke a bit as the plate began to flex as the bubbles pushed on the my mdf board below. Could be a clamping issue, I am clamping on the corners and I definitely notice the plate flexing up and down as it drills. Or maybe peck drilling would help.
Bit isn't anything special (something from home depot I believe), but I had opened it new and ran 2 plates with it before this started happening.
Splendid Some times it's easier to use a drill because you have a finer point to start the cut with a slot mill the two cutting sides of the cutting head are level and trying to cut at the same time that can make down cutting a hole difficult ,I have just picked up things over many years .
