Newbie Chamfering
Results 1 to 5 of 5
Thread: Chamfering
    Jul 2013
    Default Chamfering
    Guys I am finding myself a bit limited when it come to some parts I want to make due to the back of knowledge I posses.
    I usually want to chamfer edges and even draft some faces on parts.
    I am wondering if I need a special tool (end mill) for these operations.
    Here is a section of a typical part I would like to make. I have 2D cnc router machine (3 axis)
    1. Is the typical "finish" chamfer I see in alum parts
    2. This is the draft I mention. I would typically do this with a ball end mill if this where wood I guess.
    Thanks in advance for the help.
    Dec 2013
    Default Re: Chamfering
    To chamfer the edge, you would use a V-cutter, with the angle of your choice. Not sure what you mean by ''draft''. Normally draft is used in casting, where the wall of the mold has a slight angle to facilitate releasing the part. I think you would use a ball end bit to put a cove edge on the part or you could use a roundover (corner rounding) bit to make a radiused edge rather than a chamfer.
    Member dertsap's Avatar
    Oct 2005
    canada
    the easiest and most common solution is to use a 90 degree spot drill
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Member KH0UJ's Avatar
    Jul 2016
    Philippines
    On a custom CAM yes you can use a ball nose on that chamfer sir can you post your model sir (size, dimension, angle of chamfer) I will code it then you can try it there, examine the codes then you will definitely learn from it
    Jul 2013
    I have a 90 drill mill from Atlas tools but I don't think I should use it to chamfering alum., or should I?
    1/8" Carbide 2 Flute Drill Mill
    Instead I see they sell "chamfer mills"
    1/8 Carbide Single End Chamfer Mill 2 Flute 90
    I use RhinoCam and it has a chamfering operation that I think I have figure out with the exception of one parameter.
Chamfering
Chamfering
