Lathe threading inserts use and direction IR IL ER EL
Results 1 to 2 of 2
Thread: Lathe threading inserts use and direction IR IL ER EL
    Feb 2007
    Default Lathe threading inserts use and direction IR IL ER EL
    Is there a difference between an external left hand threading insert, and an internal right hand insert?
    Same goes for external right and internal left.
    Can an ER insert fit an IR holder? Same question for EL insert in IL holder.
    Thanks.
    Attached Thumbnails Attached Thumbnails Lathe threading inserts use and direction IR IL ER EL-16el-ag60-jpg   Lathe threading inserts use and direction IR IL ER EL-16ir-ag60-jpg   Lathe threading inserts use and direction IR IL ER EL-16il-ag60-jpg   Lathe threading inserts use and direction IR IL ER EL-16er-ag60-jpg
    Feb 2013
    Estonia
    Default Re: Lathe threading inserts use and direction IR IL ER EL
    Internal and external threads have different depths at the same pitch which might not matter much, but rake/clearance angles make a difference.
    Check the tool catalog or ask your dealer if a given insert might have all the same specs.
    Sent from my HTC One using Tapatalk
