Yes do it on your mill if it will fitDoes anyone know of a good tool for cutting hardened stainless with a Rc of 52? I have some dies that have a 24"ID that need about 1/8" taken off. Since its a die there are also a thousand through holes radially in the part. The interrupted cut is extremely hard on inserts and we haven't found a solution for a quick turn-around on these yet. We have tried TNMG inserts from Kennametal in there recommended grades, as well as Green Leafs WG-300s. There is not as much of an issue on the outside edge before the holes start (uninterrupted) vs cutting across the holes (interrupted). we may resort to grinding next, but would really like to stay away from that. I also have the option of helically interpolating the bore on a milling machine with an endmill, what do you think?
