Share Your Files Part or Art - Page 272
Page 272 of 952 FirstFirst ... 172222262269270271272273274275282322372772 ... LastLast
Results 3,253 to 3,264 of 11418
Thread: Share Your Files Part or Art
  1. #3253
    Moderator Switcher's Avatar
    Apr 2005
    Quote Originally Posted by rpage View Post
    Thanks Switcher! I just learned something! Nice!
    Your welcome.
    I have a few more Inkscape things I would like to do screencast for.
    I do all my node edits/design inside Inkscape, after you learn a few shortcuts it really is a strong program.
    I have to say that the trick I use the most, is selecting more than 1 object = Ctrl + Shift keys on the keyboard.
    For anyone looking to save some cash with software, you can't go wrong with Inkscape!
    Free DXF - vectorink.com
  2. #3254
    Registered thkoutsidthebox's Avatar
    Nov 2006
    Ireland
    Quote Originally Posted by Switcher View Post
    Look at the URL to my blog on a Yahoo search, the link takes you to www_turbotax_com
    I think they fixed it
  3. #3255
    Apr 2005
    New DXF File ---> Design 169
  4. #3256
    Jun 2005
    Default Dragonfly ???
    KSerdar,
    I'm not 100% sure this is a pic of the same 3D dragonfly model?
    Maybe it will help?
    Share Your Files    Part or Art-3d-dragonfly-jpg
    You are correct ... That is NOT the same model. I still have no idea how it fits together. But, do you have the DXF for your pic?
  5. #3257
    Apr 2005
    Sorry, I don't have a dxf for that dragonfly.
    Can you tell us, did you get that dxf from here on cnczone, If so what post/thread?
  6. #3258
    Jun 2005
    Not really sure ... I think I found it on the Mach forum on Yahoo groups.
  7. #3259
    Apr 2005
    Quote Originally Posted by KSerdar View Post
    Ok,
    I thought maybe we could track down who posted the dxf?
    I searched 3 times here on cnczone, never did find anything.
  8. #3260
    Apr 2005
    Hey guys,
    I just stumbled across something that will help save those pesky dxf files in Inkscape, you know, when you go to save the dxf with my dxfR12 extension, then all you get is the little black python window & Inkscape hangs.
    Here goes, when I have a file that hangs, all I do is resize the drawing (make the drawing smaller), that's it!
    To make the drawing smaller:
    1) Select the entire drawing
    2) Hold down the Ctrl key on the keyboard.
    3) Grab 1 of the corners, & drag to make smaller
    This only needs to be done when you want to save as a dxf file. Just don't get extreme with resizing, or it will make the dxf file lines all very sharp angles.
  9. #3261
    Registered rando's Avatar
    May 2008
    Switcher,
    I had figured that one out as well.
    If it helps, I have found that you can do extreme resizing before you do a trace bitmap,
    the file saves quicker,
    and the lines aren't sharp like they are after you do a trace.
    Extreme resizing causes some pretty signifigant errors if done after tracing the image.(double lines open pockets etc.....yuck!!!)
    Still can't do thousands of nodes though. (Like that deer sketch...)
    It would be cool if it would though.
  10. #3262
    Apr 2005
    Maybe we'll get that worked out some day?
  11. #3263
    Apr 2005
    New DXF File ---> Design 172
  12. #3264
    Apr 2005
    New DXF File ---> Design 173
