Share Your Files Part or Art - Page 195
Page 195 of 937 FirstFirst ... 95 145 185192193194195196197198 205 245 295 695 ... LastLast
Results 2,329 to 2,340 of 11233
Thread: Share Your Files Part or Art
  1. #2329
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    Quote Originally Posted by thkoutsidthebox View Post
    Hi Dertsap...can I make a quick suggestion....it might be there and I missed it. I looked at your carbide end mills but theres no shaft size. Cant buy if I dont know the shaft size! Apart from that, nice site and fantastic prices. Thanks for the link.
    Edit: Shaft length would be useful info too.
    thanks for pointing this out , typically with carbides the shank dia is the same as the cutting diameter , but i will add the extra info so there isn t any confusion
    shank diameter is already marked for each hss endmill , the shank dia on the hss isn't necessarily the same as the cutting dia. so check the info provided to be on the safe side
    also thanks for the compliment , weve been busting our butts to find decent tools at a decent price to add to the site , so far i'm quite happy with the stuff , i'm beginning to look into higher end tooling as well , obviously the price will be up a fair bit more but it will add to the variety and give the customers a better chance to find exactly what they are looking for
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
  2. #2330
    Oct 2005
    canada
    any Ramones fans
    sure i know this is dating me but anyhow legends are legends , its pretty shiney because the first thick layer of clearcoat was applyed 5 minutes ago ,
    Attached Thumbnails Attached Thumbnails Share Your Files    Part or Art-ramones-jpg
  3. #2331
    Jun 2008
    I'm just getting started trying to figure out how to do all this stuff
    so what route can a person take to convert something like this in to a .dfx
    Attached Thumbnails Attached Thumbnails Share Your Files    Part or Art-img_1964-jpg
  4. #2332
    Oct 2005
    canada
    i'd suggest you use gmax to create a solid model or use inkscape to trace it
  5. #2333
    Feb 2006
    fulton
    Quote Originally Posted by dertsap View Post
    shank diameter is already marked for each hss endmill , the skank dia on the hss isn't necessarily the same as the cutting dia. so check the info provided to be on the safe side
    Line 4 should that be SHANK or was your mind elswhere ?
  6. #2334
    Feb 2006
    fulton
    any Ramones fans
    I use laquer frequently, in particular final coats I use gloss as it has no addatives and consequently gives a harder finish. To bring the high sheen down I use a product called "wool wax" it is applied with 4 zeros steel wool and water then take a dry rag to clean the surface and dry it off .the product is made by behlen. It will give your projects a soft luster which I find attractive, you might give it a try.
  7. #2335
    Aug 2008
    Serbia
    Hi all,
    I am from Serbia, I just try CR8tracer and I love it.
    Only think that is not good is, you cant save file as a dxf, but eps can.
    After that I open the file in illustrator ans export as a dxf.Acad resize and explode...
    sheet cam for machining.
  8. #2336
    Oct 2005
    canada
    Quote Originally Posted by mike hide View Post
    LOL , oops !
    ya my mind was obviously somewhere else but no , it wasnt in the gutter
  9. #2337
    Oct 2005
    canada
    thanks ,i'll keep this in mind for future projects
    the ramones pic didn't come out as well as i had hoped , some features didn t come out as good as they should have , but i figured after all that cutting it was worth salvaging
  10. #2338
    Registered Soundcop's Avatar
    Mar 2008
    Denmark
    Question diving dxf files
    I am looking some dxf files with diving motive
    Double Cylinders , a diver
    anything that relate to diving
    BR.
    Soundcop
    Denmark
    fell free to drop by www.newtime.dk/dxf_files
    plz. don´t mind my misspelling :)
  11. #2339
    Oct 2007
    Default dxf file
    looking gor a DXF file of a 1967 Charger thanks in advance for any help I can clean up the DXF file Don't have software to export a Picture of one into a DXF file .
  12. #2340
    Registered Jamf2's Avatar
    May 2005
    ive finally taken some time to try one of the engraving bits we sell and do some more artwork , i used a 20 deg bit with a .015 step over i am more than happy with the way the cutter performs ,i'll be playing more tommorrow
    What material are you using?
    What is possible? What you will!
