Have 2 love it
when you open a file in mastercam you must tell it the extension their should be a drop down to be able to select autocad .dwg or .dxf try this ( select ) open (for file) go to where you stored the file if the box is blank look at your slecton window click on one of the arrows then a drop down should let you select dxf or dwg then select your file master cam should load it from their
ghost
New DXF File ---> Design 234
Free DXF - vectorink.com
Welcome to CNC Zone!
One method that might interest you has been discussed earlier in the thread.
Check posts # 2733, #2747, #2783 etc. by "Switcher".
-Scan or photograph the poster board.
-Open image in Inkscape software & trace path.
-Save using Switcher's DXF R12.
The better the original image, the cleaner the DXF will be.
Thanks for the advice mlind, I'll look into it a bit more.
I thought some of you, might be interested in this post here , that I made, about how to get Sketchup 7 to export FREE 3D DXF files/models (VERY COOL!).
Switcher...Salute to you.. Your contributions in this forum is Priceless...
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
Thanks weldtutor and quazga! This forum is a great tool. I will give these a shot.
Khalid,
Thanks,
I dont know if it works on 3d... but there is also a plugin for converting DXF into CNC files...its called the Phlatscript. it was designed for a foam cutter that machines foam from the bottom... SO if you use this the Z axis has to be reversed in the code... but it is freeware... get it here http://www.phlatprinter.com/viewtopi...e5d209f42e972f works on version 6 and 7 of Sketchup as well as Swirchers plugin find.
Bob
Oh and by the way... a very nice video and instruction for this plugin is available on that site as well and some dandy file downloads
Bob
This might not be a knot!
Single line tool path, V-bit.
Inside cuts .125" deep, outer ring .160" deep.
Photograph is the file cut in MDF.
I am looking for drawings of miniature tables and chairs in order to make them in wood, well apart from the skeletons of dinosaurs, the cobra, gorillas and other, if someone were to go agradecere.
Hello,
I was wondering if anyone has a .dxf of a 6 player wahoo game. As always I have been trying to draw one up but can't seem to get it right. I am planning to make another WAHOO board that has a 4 player version on one side and a 6 player version on the other side. Here is a picture of a 6 player game. Thanks in advance.
This 6 player board should work for you & fit on the back side of the 4 unit one.
I'll be looking forward to another picture of this one.
Eight players might be a few too many!
Check this LINK posts #349 & #353 for several chair DXF's that could be scaled.
Thanks weldtutor but I want more of that kind, if they look for other pages.
Next Eiffel Tower.
Tower has been cut by water jet.
Stainless steel - 3mm thickness, hight - 183 cm
