Big thanks for the Pontiac files! I can use them but the dxf file i really was hoping to get was like this:
http://www.cnczone.com/forums/showpo...postcount=1058
If anyone have it i to share i would be thankful! Have searched for it in the thread but couldn't find the dxf....
Guy's I've been reading this forum and as a machinist I have an urge to do some hobby work at home.
It appears some of you use cnc routers to carry out your work so I would like to know which model would be good for a beginner?
I would probably only want to machine no bigger than 12" square and possibly in 3D.
Software and I can source, I just need to know a router and price guide.
Weldtutor and Switcher,
Thank you both. You guys are the great.
If I can return the favor just ask.
Regards,
mlind
Hi cnchammer,
Speaking for myself I made mine from scratch. THE most expensive parts were the stepper motors, controller, and software. My total inventsment (WHEN I STARTED) was about 400 to build my cnc router. My table dimensions are 48x24 with an approximate effective cutting area of 20 x 36.
One I had all the parts I built it in 2 days. I used 1/4 all thread for the leadscrews and roller skate bearings and KCAM for the software. I had a old computer lying around that I use to control the machine with a interchangeable dremel or small router tool as the cutter. I bought my motor and controller here http://www.stepperworld.com/FET3dynamo.htm While I know that there are probably bettter controllers out there like GECKOs I wanted a plug and play system that was reasonably prices. THE same with KCAM and speaking for myself I have no regrets. It works and it works for me.
Be aware your wife won't like this as it is veryyyyyyyyy addicting and time consuming.... I looked at a complete system but to me they were priced too high for me. Of course I'm a DIYER.... Both KCAM and Stepperworld supported their products 100% with great support as needed.
I hope this helps....You can do a search on utube for a home made cnc router that you can make at home. I lost the link but its there somewhere with good instructions and a video of how to. In the end I would build your own. Is really pretty simple just a little time consuming. BTW here is a picture of home brewed cnc router.
Firebird dxf
“ In questions of power, let no more be heard of confidence in man, but bind him down from mischief by the chains of the Constitution.” Thomas Jefferson
jhowelb, thank you for the file that i wanted but i cant open it in mastercam mill 8. Tryed also to "export" / transfer the file but it didnt accept it...... Is it my program or am i doing wrong?
Swemill,
You said you tried to "export" the file? (Export is to send) "Import" is to bring in and is the command you are needing. Mastercam is very good at "Importing" DXF files.
I am in need of an eagle head (side profile) in dxf or dwg format. Can anyone help me with this?
Brian
Ahh.... Sorry for my bad english... My program is in not in that. I mean "convert". I have imported the file and tried to convert it with no luck but i will try again.
Thanks!
I am wanting to know the best way to convert an image. I am looking at a poster board cut out (and get asked to do this alot) and need to convert it to a clean dxf file to laser cut. It is time to stop killing myself freehanding the artwork if that is possible. What software and what hardware do I need.
Thank You
Does anyone have a laser cut or plasma cut DXF of the Taz??
