Originally Posted by
fizzissist
Looks like a strong contender for face threading on a lathe.
A rugged CNC would give you the ability to use a rougher and finishing tool, and control the pitch/depth-cut increment accurately.
I can see where tool wear would be a problem with the 'engraving' approach.
The problem with a multi-thread tool is that the diameter varies considerably between the inner and outer grooves, leading to problems of side relief and potential dragging. Not what you want.
If you are going to use an engraver type tool, have you considered something really rugged, or CBN? I don't know how you're going to get around the spindle-on time, unless you mount a dedicated motor or speed doubler.
I've been involved with making similar grooves in a laquer coated aluminum disc in a vertical lathe, but we were making the cutting tool jiggle a lot, and using a ruby that didn't rotate. Chip control was actually a big problem... Ultimately, the biggest problem was making QC happy, because the measurements were translated into acoustic energy, and every QC guy had a subjective opinion. The lathes we used were Scully and Neumann.
