cycle time formula
Results 1 to 8 of 8
Thread: cycle time formula
    Oct 2004
    Default cycle time formula
    Moderator HuFlungDung's Avatar
    Mar 2003
    Cycle time = (path length in inches / feedrate inches per min)
    Every change in feedrate requires a seperate term, and all rapid movements would also have to be sorted out in the same fashion.
    Registered MetLHead's Avatar
    Mar 2003
    I recently added this function to NCPlot. Just load in the G-Code file then go to Tools | Show part info. You can enter your machine's rapid rate and tool change time too.
    www.ncplot.com Just click the NCPlot v2 link on the left then the beta 17 download link.
    Thanks,
    Scott
    Attached Thumbnails Attached Thumbnails cycle time formula-partinfo-jpg
    Registered BlueChip's Avatar
    Jun 2003
    Massachusetts
    Default CycleTime Estimating
    If your looking for a software package to help you out ... I would invite you to look at our KipwareQTE ... you can get either the CycleTime estimating as a stand alone or get it with the cost estimating module as well.
    Info at www.kentechinc.com
    You can create a database of your shop machinery specs ( rapid rate, tool change time, strokes, etc. ) and then create a database of your cutting parameters for materials for various machining operations ... the software then uses that info to auto-calculate machining cycletimes. You can create then auto create routings or import that info into the costing module and easily add material costs, tooling costs, etc. to create a quote / cost estimate.
    Easy to use and gives you consistency and accuracy in your quotes ... less than $800 complete.
    Thanks to CNC Zone for the opportunity to post.
    Oct 2003
    There's also ME Consultant Professional ($100), which will calculate all your machining times and costs very quickly. Now being promoted by CNC Concepts ( http://www.cncci.com ), a leader in CNC training and education for many years.
    Software For Metalworking
    http://closetolerancesoftware.com
    Sep 2003
    I would also recommend ME Consultant, it is a very effective program for cycle time, feed and speed recommendations and a lot of other neat stuff.
    I MUST tool for every programmer.
    Lars
  7. #7
    Mar 2004
    I am amazed that MasterCAM doesnt have a cycle time calculator built in - or does it and I am looking in the wrong place?
    It seems like such an obvious thing
  8. #8
    Aug 2005
    Sure it does
    Backplot the selected ops and it'll give you the runtime
    Jim
cycle time formula
cycle time formula
