3dprintforums logo
CNCzone Network:  RFQwork :: 3Dprintforums :: Welderzone :: Google+ :: Our Facebook :: Twitter :: SiteMap
Results 1 to 11 of 11
Thread: New CNC lathe conversion plans
    Site Owner CNCadmin's Avatar
    Mar 2003
    Blog Entries
    1
    Rep Power
    10
    Thank You,
    Paul G
    Site Owner-Webmaster-
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Jul 2004
    Rep Power
    10
    I have a set in my hands, it is a very nice conversion. Once I get thru with the mini-mill, I'll write a review on the lathe plans.
    Mar 2003
    Blog Entries
    1
    Rep Power
    10
    Have you started your conversion yet?
    Thank You,
    Paul G
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Registered mark c's Avatar
    Sep 2004
    US of A
    Rep Power
    10
    I've got the plans too. They're very well done. I'm probably 1/2 way done. My micro-mill just took a s**t so I gotta fix that before I can get back to it. I'm using the Hobby CNC 200oz/in stepper kit and thats pretty much done too. I'll post again soon as I go
    Mark
    Registered Otokoyama's Avatar
    Oct 2004
    U.S.A.
    Rep Power
    I'm mostly done with the Steele mini-lathe conversion: http://home1.gte.net/res0d176/MiniLatheCNC.html. I have yet to do the Spindle Sensor and Guard, though am anxious to get cutting metal. So, far I've made some promising test cuts under jog control. I've got to come up to speed on Mach3's lathe features before running some code.
    Mar 2003
    Blog Entries
    1
    Rep Power
    10
    Very nice, I'm looking forward to doing my someday soon.
    Thank You,
    Paul G
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
  7. #7
    Feb 2004
    hh
    Rep Power
    11
    Quote Originally Posted by Otokoyama
    your going to be moving that keyboard; i can say that from experiance
    mine is above the lathe on top of a shelf that carries my 3 halogen lights; it works good in that position and it keeps it out of the crap
  8. #8
    Oct 2004
    U.S.A.
    Rep Power
    The keyboard is already covered with swarf, but it's impervious to that and the location is very convenient. A shelf above the equipment is an interesting idea. The worst problem with this keyboard location seems to be that I carelessly place objects right on the keyboard (e.g. chuck key) which occasionally depresses keys.
    The Steele conversion is working flawlessly. I highly recommend this to people who are considering converting their lathes. Ron Steele's mill plans look every bit as good.
  9. #9
    Feb 2004
    hh
    Rep Power
    11
  10. #10
    Banned
    Apr 2004
    Norway
    Rep Power
    I would use a box structure instead of the ones shown on the picture of the conversion. That would be much more torsionally rigid. I know, as I did that on the Y-axis of my mill, and even if much thicker rods are used, at certain speeds (resonance ) this will influence the torque of the stepper, it can even stall out. I'll have to redo that part. My X-axis use a thick-walled tube as standoff, and it has no such tendencies.
    And what about the heavy stepper hanging out at quite a distance? The rear part of the slide will probably bear on the underside instead of on the top as originally designed. If it does not have a large surface and good material pairing, it will wear out rapidly.
  11. #11
    Oct 2004
    U.S.A.
    Rep Power
    Quote Originally Posted by Stevie
    My "impervious" keyboard warped after a thorough soaking with Tapmatic Dual Action Plus #2. :frown:
    Quote Originally Posted by ESjaavik
    I was concerned about this and went with a lighter motor on the cross slide to minimize whatever effects this might have. The motor mount is quite rigid as is, and I didn't notice any tightening of the cross slide after the motor was in place, as might be expected if the bearing surface was affected.
