Can Keizen foam be CNC cut with a mill?
Results 1 to 3 of 3
Thread: Can Keizen foam be CNC cut with a mill?
    Jul 2013
    Default Can Keizen foam be CNC cut with a mill?
    hi guys, like the tittle says. If so can someone please recommend a tool bit?
    May 2016
    Default Re: Can Keizen foam be CNC cut with a mill?
    Hi FoxCNC1,
    There is a guy on youtube, JOHNGRIMSMO, that was cutting foam on their mill. It might contain some good suggestions, if you haven't already found a solution. I think it was for their knife cases, but the idea is the same.
    Member awerby's Avatar
    Apr 2004
    Flexible foam is pretty much impossible to cut with an endmill; it just wraps up on the tool. You'd be better off using a hot knife mounted in the spindle (somehow - it might take machining a holder). Just remember to edit out the "M3" from your G-code, so it doesn't start to spin...
    You can get one here: https://www.fastcap.com/product/kaizen-foam-hot-knife
