Just In Cutting fiber cement sheet
Results 1 to 10 of 10
Thread: Cutting fiber cement sheet
    Jun 2017
    India
    Default Cutting fiber cement sheet
    Dec 2013
    Default Re: Cutting fiber cement sheet
    Cement board is normally cut with abrasive or diamond saw blades. If you are trying to do this on a CNC router, a diamond burr of some kind might be your best option. Feeds & speeds? Start slow and bring the speed and feed up to where the machine is happy. A water spray will help remove the dust and help keep the tool from loading up.
    Jim Dawson
    Sandy, Oregon, USA
    Gold Member LeeWay's Avatar
    Jun 2004
    If you don't mind the asking, what kind of a profile are you trying to cut?
    If it is details in a shower stall or surround, there are easier products to cut. I have cut quite a bit of this and hardy panel with just a standard diamond saw blade and always have someone squirting a little water ahead of the cut or smaller pieces are cut on a tile saw with the same kind of blade.
    You can make some fairly intricate cuts with those.
    Lee
    Jun 2017
    India
    This is the design i am willing to cut on my cnc rauter.
    This is the first i am going to cut cement sheet i want to avoid wastage of Cutting fiber cement sheet money.
    Size will be 8×8 feet.i will cut it two parts 2(4×8).
    Thanks for your response
    Sent from my Redmi Note 3 using Tapatalk
    Jun 2004
    Nice project.
    Good luck and let us know how it turns out.
    Lee
    Jun 2017
    India
    Quote Originally Posted by LeeWay View Post
    Nice project.
    Sure my friend
    First i will try on smaller sheets just to be sure
  7. #7
    Member awerby's Avatar
    Apr 2004
    Why are you cutting that pattern into fiber cement sheet? It seems like a waste of time, money and material to me, but maybe I'm missing something? Are you covering it with tile or something afterwards?
  8. #8
    Jun 2017
    India
    Quote Originally Posted by awerby View Post
    That was for my client thankfully i changed his mind.
    He planned to put that sheet in mild steel frame.
  9. #9
    Apr 2004
    Raw cement board (at least the type we've got here in the US) is pretty ugly, and crumbly around the edges. It wouldn't support fine cutouts like you've drawn. So what are you doing instead? You could cut that out of a steel sheet with a plasma cutter, put it in a steel frame and it would look a lot better.
  10. #10
    Jun 2004
    I had assumed it might be something that gets a coat of stucco over it or something to that effect.
    The material to use for that though in a low traffic area would be styrofoam and then mesh with a portland coat and then a couple top coats. Much easier on the machine and tools though clean up might be about the same.
    Lee
