- Best Foam for Milling 3D Sculptures
Hi there!
We recently purchased a 7-Axis Robot and are looking to create some 3D sculptures and props with our machine. Before we get started, I wanted to see if anyone had any insights or advice on materials... specifically foam.
QUESTIONS:
- In your experience, what are the best types of foam to use for milling 3D sculptures and props?
- What density of foam would you recommend for milling 3D sculptures?
Also, if you have any recommendations for the type of foam finishing / hard coat materials that we should b using after milling, I would love to hear advice on that, as well.
I would appreciate any insights or advice that you have. Thanks in advance!
- You may not post replies
- You may not edit your posts
Forum Rules
