You can buy 1/4 inch with 1 inch cut ''endmills'' at your local hardware store. They are solid carbide router bits, they work great in all materials if you are careful. And the best part is you can get them on a Saturday afternoon. I normally keep a few in the drawer.
Longer length end mills are readily available from various vendors. Google ''endmills'' for vendors, there are hundreds of them. End mills with a larger cut than shank are also readily available. Carbide tipped router bits work well also, and again available from your local hardware store.
